[2.3 20V 7A] [Coupe B3] ABS problem on CQ20V
Hi guys, i have problem of ABS light ON after some mileage. Relays is good, fuses either, new 3 abs sensors...Every sensor puts almost same resistance and while i turning with wheels, voltage is there..Any ideas? CV joints are new and abs tooth ring either...So no rust on ring
ABS diagnostic was clean - no error codes
Ostatnio zmieniony 15 kwie 2017, 18:22 przez bobo23, łącznie zmieniany 1 raz.
- Krzysiek 84
- Junior Admin
- Imię: Krzysiek
- Silnik: 1.9 1Z
- bloku
- Imię: Michal
- Silnik: 2.3 NG
At first check sensors resistance -what they showed you? Electricmeter should shows between 1100-1200. Best of it is 1150. Also You can check how much is change after moving wheels.
I had the same problem in Audi Coupe Quattro 2,0 NM (one of four new sensors broke down)
Było:80 YN,80 AAH,80 YN,Coupe DS,100 AAR,80 DT,90 JS,90Q 7A, CoupeQ NM,CoupeQ AAH,A6Q ASN,S6 AQJ,S6 ANK,80 Avant ABK,A4Q APR,Cabriolet AAH,A8 ABZ
Jest: 80 `94 Ginster Yellow czyli Bee NG
It shows during driving...no before drive and no after drive
When i measured voltage on sensors...The numbers increased/decreased depends on the speed of rotating
On the pictures u can see a resistance...every sensor is around 1150-1200 ohms
3 sensors are new, 1 is old...but the numbers of all 4 sensors are almost the same...
front right (old) 1 186
frond left (new) 1 198
rear right (new) 1 128
rear left (new) 1 172
- bloku
- Imię: Michal
- Silnik: 2.3 NG
Ok. I see, my firewall stoped the link.
If they works that seems that conttroler (under the back couch) has an electrical problem. What is happening after using difflock on and after off? ABS are working or crash down after few km?
- bloku
- Imię: Michal
- Silnik: 2.3 NG
In my opinion controller of ABS made some problem, probably no conections between sensors. If You have ON/OFF ABS switch on board try to check also.
The only solution which i see are on controller or switch.
- bloku
- Imię: Michal
- Silnik: 2.3 NG
Switch You can check by multimeter - signal between connectors.
Not ECU (engine modul) . ABS has own controller - 857907379 made by bosch
